hi, im looking for the wire i would need to send a computer screen to my tv, if possible wireless butim sure its much more expensive, thanks
Results 1 to 15 of 15
im sure i have video out, i bought a card that let me send video in cos i remeber i only had a video out card, is there a wire id need or something
i really dont have a clue, isnt it all standard, i have a sell, 8400 dimension
Originally Posted by goldenvirginia
sending the signal to the TV is going to open a whole other world of computing for you. Once you start running into your problems you may want to visit www.htpcnews.com to get answers to more problems.
Media Center PC's are great though. -
hmm, im looking on a website now, i need it to go into my tv with a scart socket, i dont know what type of plug goes into my computer, remember i am in the u.k
thanks for the help -
hi, it may be a bit to much to ask but im afraid of ordering the wrong cable, could someone find a link to any website with the cable on it and with a picture so i know what im looking for, all i can find is 4-pin cables
I'd suggest (although I have no clue about the UK) that this one should do the trick:
from: http://www.tvcables.co.uk/cgi-bin/tvcables/PGV673.html?id=xac8gvc3
It was as easy as going to google.co.uk and searching for "s-video to scart cable".
Google is your FRIENDIf in doubt, Google it. -
http://www.ebuyer.com/customer/products/index.html?action=UFNTaG93UmVzdWx0cw%3D%3D
http://www.pyramid.com/ProductList.aspx?CategoryId=EH
hi, pleas may u tell me if the products in these links will work
thanks again for all the help
send video to TV over ethernet?!
By kevbodian in forum Video Streaming DownloadingReplies: 17Last Post: 22nd Dec 2011, 20:13 -
Send image from laptop to TV
By a_2008 in forum DVB / IPTVReplies: 2Last Post: 9th Nov 2010, 05:41 -
How send 1-hr DVD over internet ?
By rdfarr in forum Video ConversionReplies: 11Last Post: 8th Apr 2008, 23:22 -
Send to TAPE (to another PC - Emulation)
By Soreen in forum Video ConversionReplies: 5Last Post: 18th Feb 2008, 10:44 -
How can I send video out of my PC to a dvd recorder?
By pugvader in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 08:12
