Hi
for strange reasons I've decided that I would like to put a TV card into my PC - situated in a spare bedroom that's now "my room"! I would like to be able to view digital tv including "freeview" channels (I'm in the UK). As important I would like to be able to record on to my hardrive for future editing and transfer to dvd. I also don't want to spend a fortune! I've got a nearby arial point that is part of my house arialing - there's an amplifier on the circuit and I know from TV use that the picture quality / reception is great.
Can anyone give me some inexpensive suggestions please?
I'm sorry if I've posted this to the wrong forum but I guess that a moderator will move it if I have.
Ta very much.
Best regards
Ian -
It depends what you mean by "I also don't want to spend a fortune!"? Over the air HDTV cards are about $150US and up.
DVICO is one of the cheaper brands.
If you look to the left for 'Capture Cards', you can plug in your requirements and get a few cards that may do what you want. Being in the UK, you would want to pick a card that would work with the formats and systems used there.
For regular TV, the Hauppauge cards work well and capture directly to MPEG format, so they are convenient.
Or if you are really short on cash, the AVerMedia cards are inexpensive, but at a lower quality and not as versatile as the Hauppauge.
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Built In Multiple Card Reader Won't Recognize SD Card
By V Bot in forum ComputerReplies: 9Last Post: 8th Oct 2011, 00:01 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 16:51 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
