Hi,
I am using Video Studio to compile my video footage and I used to have a 'Cross fade' effect filter (I think it's name is 'cross.vfx' somewhere under the Video Studio directory.
I have just reinstalled Video Studio and it seems to have removed the filter and I don't seem to have a back up of this file.
Can anyone please send me this filter file again please? Thank you in advance.
Regards,
anon
b&c;Average;balance;Blur;Brightness & Contrast;Charcoal;Color Balance;Colored Pen;colorpen;colorshf;ColorShift;Cropping;diffract ;Diffraction;Emboss;Hue && Saturation;hue;Invert;kaleido;Kaleidoscope;Light;M irror;mono;Monochrome;Mosaic;Oil Paint;oilpaint;Pinch;Punch;Ripple;sharp;Sharpen;St ar;Throw Stone;throwstn;Vignette;Water Flow;waterclr;Watercolor;waterflw;whirlpol;Whirlpo ol;Wind;zmotion;Zoom Motion
I can't find the filter u mentioned and can find the above only.
Maybe u mix up some other editng softwares. -
sorry, it should be a transition effect filter.
So it should normally sits under Effect -> F/X I think the name could be fade.vfx, but i have that file already. The reason i asked for it was because i had just put togther a project file in Video Studio before i re-installed it. I used that effect in my project. Now when i tried to bring in that project to finish it off, the programs tells me that it couldn't find that transition effect filter.
Fade to black effect
By kimstips in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2011, 12:03 -
Vegas 10: Mid-project cross-fade (with sanity)?
By Ander in forum EditingReplies: 0Last Post: 22nd Jan 2011, 04:05 -
VirtualDub: Fade between clips effect
By David_UK in forum EditingReplies: 5Last Post: 14th Apr 2009, 15:25 -
how can I add "Fade in / Fade out" effect in my video clips
By mb508 in forum EditingReplies: 5Last Post: 9th Jul 2007, 17:02 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 21:58
