Hello there, first question and I most certainly am a newbie!!
I have a collection of AVI files, which recently I have begun to archive to DVD+R discs, using the "Convert AVI to DVD" wizard within WINAVI.
To test each DVD I have been watching the disc on my PC (the same PC that I have previously viewed the AVI files on , using VLC).
When watching the burned DVD version, the volume is much lower than the original AVI version (yes I have checked that my volume knob is at the same level!!).
Is this a common phenomona when converting from AVI in this way?
cheers all
I would try it in a standalone player before you adjust the volume. But if you need to make a adjustment VirtualDub can do that.
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 16:06 -
Converting AVI to DVD using DVD Flick: low quality result
By e2p in forum Video ConversionReplies: 13Last Post: 28th Oct 2010, 10:50 -
DVD footage with low volume CAN WE FIX IT ??
By rockonvidtrade in forum AudioReplies: 7Last Post: 11th Jan 2010, 11:27 -
Winavi Stuck while converting Rmvb to avi.
By godbowen in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2008, 10:02 -
avi to dvd converting settings for winavi convertor
By soft in forum DVD RippingReplies: 6Last Post: 23rd Jul 2007, 23:45
