I finally managed to get WME to accept M2V files for conversion. (I used Cyberlink's Power DVD mpeg-2 decoder. It works most of the time.)
I'm changing over several short cartoons. Some translate fine to WMV, but there are a few that have problems with pans.
I don't know if it's an interlace problem. I'm not seeing the jaggy edges that would indicate interlacing. I did choose "de-interlace" in the preferences anyway.
Instead, there's a noticible stutter on left-right pans.
Here's a short example of what I'm talking about: http://animatusstudio.com/sharksbadpan.wmv
The car seems to be moving fine, but the street and buildings are jumping.
Any ideas?
Actually, from what I can tell, the cars are doing it too. Almost looks like you are dropping frames. What are your input and output specs?
Google is your Friend
Windows Media Encoder (WME) Error Log.
By nomo0808 in forum Video Streaming DownloadingReplies: 1Last Post: 6th Oct 2011, 03:41 -
Strange Port Conflict in WME
By FarmerCharlie in forum Video Streaming DownloadingReplies: 0Last Post: 28th Mar 2011, 12:13 -
No sound in WME with USB capture card
By bomb jack in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2011, 04:40 -
VLC , WME convert
By arwa in forum Video ConversionReplies: 5Last Post: 30th Oct 2007, 12:58 -
Audio doesn't broadcast in WME
By versionII in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 11:40
