converting avi to dvd,cool. but i need to create chapters on the new dvd ,after doing conversion. how do i can do this ?
Results 1 to 9 of 9
Depends on your authoring tool. For me, I get the frame numbers/times from Virtual Dub at the prceice frames I want to put chapters. Then In my authoring application, I put those values in. If I use IFOedit, then use frame numbers. If DVDauthorGUI, then times.
Darryl -
Common authoring programs like TMPGEnc DVD Author allow you to place your own chapter points manually on a timeline or to automatically place chapters at a time interval which you choose, like every 10 minutes, or you can tell it to place a number of chapter points such 15 in your video which it will insert spaced equally apart in time.
https://forum.videohelp.com/viewtopic.php?t=291744
Is what you want ...
Update : The guide dose look as though it share's some similarities with the guide in the post below , but that is where the similarities end .
The guide gose way past the simple splitting of a title into 1 gigabyte chunks , which might I remind user's , it dose this by default provided you dont go messing with the internal default setting's .
Some major point's :
1: Acurate for the generation of chapter point's .
2: Acurate for the removal of unwanted material .
3: Work's for both pal and ntsc , both in various sized format's -
Hmmmm .....Originally Posted by Bjs
That guide looks remarkably similar to this guide:
https://www.videohelp.com/guides.php?guideid=723#723If in doubt, Google it. -
the thing is , i have a dvd that as no chapters? so i need to include some chapters on . so i ask is how i can do this ?
I'd suggest following Darryl's post...
Open your video in V/Dub or possibly any player (it'll just be less accurate) & note the time or frame # where you want a chapter to start. DVD Lab has an autochapter function if you just want chapters and don't care where they are. -
nero does not inclued chapters ?! so with my dvd in hands i need a tool now to put some chapters ?!? sorry if i can`t understand to good or make the question too clear .
Create own Subtitles
By kerpal in forum SubtitleReplies: 11Last Post: 16th Oct 2013, 10:19 -
How to do they Create Motion in this example
By Thread7 in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2012, 16:17 -
How to create photomation?!?
By dabigwu in forum EditingReplies: 3Last Post: 2nd Mar 2010, 22:52 -
create slideshow
By shashgo in forum Newbie / General discussionsReplies: 27Last Post: 14th Aug 2008, 12:13 -
Final Cut Express 4 can I create chapters for a DVD I create
By Jabroni4872 in forum MacReplies: 1Last Post: 18th May 2008, 12:36
