As the title says the audio on my downloads are fine when i play them on media player classic and on real player, but once i convert it and copy it to dvd the audio goes out of sync from ht very start of the film. This doesnt happen to all my downloads and theres no pattern to the ones that it happens too. Any ideas to why this may be happening would be welcome.
are they out of spec while they're dvd files (AUDIO/VIDEO_TS folders?) or only when you actually burn them to dvd?
i suspect you're converting from NTSC->PAL, or viseversa and losing your sync. -
Yes they go out of sync when i convert them to AUDIO/VIDEO_TS folders.
So you think it is because they are ntsc and i am converting then as pal?
If this is the case is there anyway round this?
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 19:02 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
