  1. Im still not sure which DVD player will work the best for me. Any suggestions would be appreciated. I burn alot of concert videos off the net which come in various formats and my lack of knowledge hinders me from makeing my new DVD player purchase. I bought a Toshiba SD-v392su VHS/DVD combo and its a piece of crap. Lot of skipping on my DVDs and some dont play at all. I then tryed my daughters cheap Sylvania and all my dics work. I guess the saying "you get what you pay for" doesnt apply to DVD players. Anyway what is the most universal player? I would like to get a multi-disc player so I can load it with a bunch of DVDs and let it play random. Please help because I dont want to get burned again like I did on the Toshiba. Thanks.
  2. Banned
    Freedonia
    Anything that plays a variety of formats should be OK for you. Your requirement for a multi-disc player may not be the best idea though. My personal experience has been that these players have a lot more problems than single disc players. The only multidisc player I ever owned was an Apex and it worked like a champ for me, but it couldn't do random play. It may be hard to find a player that can do that. It's worth saying that the Apex model I had was notorious for quality control problems and had tons of returns. I got one of the few good ones.
    I have had a negative opinion about Toshiba for a long time. I remember about 4 years ago when they were selling a DVD player that wouldn't play VCD at all. It wouldn't play it on burnable media or commercial media. The guy I knew who owned it called their support line and they said "Yeah, it doesn't play VCD at all". It says a lot about the company that they made a player that didn't even support VCD because they figured no one in America would have any need for that.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    The problem you currently have may not be a "bad" player, you just need to use different media.
    Keep in mind that even if someone suggests a really good player that does everything that you want, doesn't mean it will be compatible with your current media and collection of already burned discs.
    Google is your Friend
  4. The Oppo DVD player is rated the best and it will play just about any format.
    http://www.oppodigital.com/opdv971h.html
