System: 1.7gh P4, XP, Premier 6.01, Dazzle DV Bridge, 768MB Memory, Capture 2 2nd 80GB 7200 drive.
I have done a couple hours capturing from an 8mm analog tap with pretty good success.
But, I just captured 10GB worth (first file 4+ GB)from a Beta tape, and have a little experience that brings some questions:
1. Dropped about a max of .4% of my frames (i.e. dropped 14 in 3500). Is that a lot to worrry about? (I had defragged my 2nd drive by the way)
2. When I bring my file into Premier, there are long periods (i.e. 7 seconds long), that appear to have thet same frame repeated, and no audio. Is this what happens when "a frame is dropped"? I can put it on the timeline, and lift out the dead spot, and it appears when I play it back that maybe one frame dropped.
3. When I first dropped the clip on the timeline and tried to play it/preview it, it would not play back. After editint out some of those "empty spots", it all of a sudden now plays back.
Not getting any input on this, but thought I'd drop a little more info just in case someone gets interested in helping me out.
I have defragmented my drive, and it helped some. But I have found that capturing with Scenalyzer Live is the only capture method that seems to not give me the capture without the problems listed in item 2 in my first post, although it reports a higher amount of dropped frames.
I just tried Vdub, and can't even get it to capture. It gives me an error of "cannot find a driver to draw this non-RGB image format". I don't get that at all.
Neatvideo strange behavior
By themaster1 in forum RestorationReplies: 51Last Post: 12th Feb 2012, 08:11 -
Philips DVP3260 and strange Play/Pause behavior
By Jagg1010 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 11th May 2010, 17:23 -
LG DN788 ~Very Strange Behavior~Need suggestions
By buffee in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th Feb 2010, 18:22 -
Strange behavior of the 5990
By ahhaa in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Aug 2009, 11:27 -
Strange behavior of Outlook Express
By ahhaa in forum ComputerReplies: 4Last Post: 27th Jul 2007, 09:29
