  1. Anonymous
    Guest
    I am planning on getting a laptop. Wht technology should I get?
    AMD Turion™ 64 Mobile Technology ?
    I want a AMD processor. Should i get dual core?
  2. Banned
    Feb 2005
    USA
    Not enough info.
    Two important pieces of information are missing:
    - How much is your budget?
    - What do you want the laptop for?
  3. Anonymous
    Guest
    no budget limits
    no serious gaming
    or video processing
    I was looking at this one
    Pavilion dv8040us Notebook
  4. Banned
    Feb 2005
    USA
    That's not bad but if you don't plan on doing anything in the realm of video processing or gaming a machine like that might be overkill. Why spend a ton of money on a computer you'd only use maybe 1/3 of it's power? You may want to examine the budget laptop threads in this forum section for other laptops more suited to your needs.
    Jul 2002
    Up in yo' bitch.
    You could by a $499.00 Dell laptop and satisfy all your needs. No need for dual core or huge processing speeds.
