I agree.
Firewire is the better system but it has less uptake and chipsets can be problematic. You will rarely get a problem (nowadays) with USB2 HDDs but the same cannot be said necessarily for Firewire.
Regards.
Results 31 to 36 of 36
Michael Tam
w: Morsels of Evidence -
Use what works for you. Some people are satisfied with USB2 and some with Firewire. But you can always switch between the two.
Although many hard drive operations may be faster using firewire instead of USB2, my gut feeling is that the same doessn't necessarily hold true for DVD burners. I'd expect the benchmark characteristics would be completely different from one another including seek times, burst data rates, sustained read, various writing operations for various sized packets, the way buffer memory is utilized, etcAre the above assumptions agreed? What is left out?
As an exaggerated parallel, I wouldn't expect a 1.44MB floppy drive to operate any faster on a 3GHz P4 than it did on an old 486. -
but at 16x write (22MB/s) or sustained read it is looking like a hard drive.
http://www.kiva.org/about -
Agreed.
At high burn speeds, Firewire would perform better than USB2 (assuming you don't have a chipset compatibility problem).
Regards.Michael Tam
Agreed.
The reason I posted my Benchmark tests is because I hate misinformation. They advertize that USB 2.0 is faster than Firewire, but in the real world it's the other way around. In my tests, Firwire is about 80% faster using the same HDD in the same enclosure, tested on the same Laptop.
I don't use external buners, so I can't say if it would make a difference.I stand up next a mountain and chop it down with the ledge of my hand........ I'm a Voodoo child.... Jimi Hendrix,
Firewire to USB ?
By vhelp in forum ComputerReplies: 5Last Post: 11th Aug 2011, 21:03 -
firewire to usb 2 cable
By pavilion1250 in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2009, 21:01 -
Can I capture with USB 2.0 or does it have to be Firewire?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 7th Feb 2009, 13:19 -
USB or firewire
By rjack in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2009, 21:42 -
Firewire to USB
By DNCR556 in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2007, 10:45
