I'm trying to convert several .wmv's (using the wmv3 codec I believe). Every time, FFmpegX pukes on it. Any ideas?
Here is the error log:
Encoding started on Tue Feb 28 08:25:12 CST 2006
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x1b8e704
ASF file format detected.
Too many video packets in the buffer: (2888 in 8394115 bytes).
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
ASF: No audio stream found -> no sound.
VIDEO: [WMV3] 352x240 24bpp 1000.000 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:6 fourcc:0x33564D57 size:352x240 fps:1000.00 ftime:=0.0010
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=352 h=240]
Requested video codec family [wmv9dmo] (vfm=dmo) not available.
Enable it at compilation.
Read DOCS/HTML/en/codecs.html!
Exiting...
Requested video codec family [wmvdmo] (vfm=dmo) not available.
Cannot find codec matching selected -vo and video format 0x33564D57.
Trying to convert from wmv to any other format using Daniusoft, need tips
By VidNewb in forum Newbie / General discussionsReplies: 1Last Post: 20th Mar 2011, 08:07 -
CLI to WMV/VC1? (WMV3)
By RogerTango in forum Video ConversionReplies: 11Last Post: 9th Nov 2009, 23:02 -
Unable to convert some WMV files to Ipod Touch format - Why?
By tradertt in forum Video ConversionReplies: 14Last Post: 8th Oct 2009, 05:22 -
Faulty wmv3 (9) codec problem
By Darius_bd in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2008, 18:30 -
ASF (wmv3 codec) converts without sound
By mehlkelm in forum ffmpegX general discussionReplies: 2Last Post: 9th Jan 2008, 11:05
