I found a couple of other threads on this but can't seem to get it right. Maybe I'm just missing something obvious. I got a DVD+R set of the SciFi channel's 'Invisible Man' off ebay. While the audio and video quality is great, the audio on the first 7 episodes only comes out of one speaker. I know just copying the left channel to the right won't be true stereo, I just want it to sound better and give the receiver something more to work with. Apparently, the easiest thing to do is convert the ac3 to a wav, copy the left ch. to the right, convert back to ac3. I tried to open the ac3 with ffmpeg but it couldn't find anything to work with. So basically I need a 'step by step,' ie. opening, extracting, converting, reinserting to file for burning, etc. Also, even though ifoedit says the audio is 2 ch and sound is only coming out of one speaker, is the audio really mono (left speaker only), or 2 ch with little or no sound in the right speaker? If so, what sort of extra step is necessary? Any advice would be greatly appreciated.
Each disc has 4 episodes with a basic interactive still menu with no audio. The audio_ts folder shows 0 bytes, video_ts about 2GB. Ifoedit says the video is MPEG2 with AC3 2 ch audio. These are the tools I currently have:
Audacity (someone said it reads mp2 and ac3, but it doesn't)
DVD Decrypter
DVD shrink
ffmpegui03c
ifoedit096
InterVideo Win DVD
First you will need a guide to extract the files from vob to mpeg, there are quite a few guides available to choose from.
After you have the mpeg files, you can use a program such a Goldwave to extract and manipulate the audio.
After the audio is corrected, you can then use tmpgenc to remux the audio/video and reauthor the dvd, or depending on your authoring software, add the audio/video files to your software and reauthor.Google is your Friend
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 22:46 -
Best way to convert DVD-r w/ 1 channel audio to mono?
By progrocktv in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2009, 16:57 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
Stereo AVI gets converted to double mono using L channel while transcoding
By AppliedCD in forum Newbie / General discussionsReplies: 2Last Post: 16th Aug 2007, 23:38
