I have a Pioneer DVD-RW DVR K13A drive that works fine in most cases. Cd's are no problem and original dvd's are never a problem. However some copied dvd's including ones I have copied myself don't register in the drive. As in it says 'please insert disk' when there is one in there. And for other copied dvd's it sometimes thinks they are cds.
I run Windows Xp and have no other problems. I have tried various codecs and even checked Pioneers website out but there is no mention of my specific drive.![]()
Could someone spare a little bit of their computer genius to someone not so giften in the art of computer manipulation????? - but not a total moron either.
New disc sometime has a thin layer of chemical on t. Try use lens cleaner and soft cloth to clean thge disc, and try again.
What media are you using? Have you tried a different brand/type of media?
You also need to ensure you have finalised the session/closed the disc.Google is your Friend -
The only reference that I can find for the k13a drive is in reference to Toshiba laptops. Apparently this is an OEM drive used by Toshiba, but I could be wrong.
Why don't my DVD copied onto hard drive play any more?
By kib in forum DVD RippingReplies: 1Last Post: 16th Nov 2010, 06:39 -
Can't play copied DVD on DVD player
By mblaine in forum Authoring (DVD)Replies: 9Last Post: 4th Jan 2010, 08:01 -
Can Sony PS3 system play copied DVD movie?
By coody in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Jan 2009, 01:33 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26 -
Copied dvds wont play on my PC
By Rgalan in forum Newbie / General discussionsReplies: 10Last Post: 21st May 2007, 17:34
