Does anyone know of a site, forum, or any other place I can go to find a list of all the DVD players that can be made to play multiple regions?
I used to live in the UK and have a large collection of Region 2 DVD's. Now that I am back in the US, I need to get a DVD player that I can get to play both my Region 1 and Region 2 DVD's. I dont care if I have to BIOS flash it, enter a special remote control code, etc, as long as it can be made to play it with relative ease...i.e...no swapping of chips on the circuit board.
Thanks,
Brian
Philips 642 is best bet
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
I don't know of a master list, but you can do a Google search for 'region free DVD players' and get some companies that sell modified players that will do what you want. Check their warranties and the companies reputation before you purchase.
One company is http://www.world-import.com/dvd.htm . There are others, and I am not recommending any company specifically. The modified players are sometimes a better deal if you don't want to try to modify the player yourself and you want to keep a warranty in place. -
Thank you. I will check do some more googling to see what I can turn up. I am actually not too concerned about warranty as I typically buy DVD players around the $50-$75 range. I am considering the 642 mentioned in an earlier thread. I am just confirming it will also be able to output DTS. If so, I will probably pick it up from a local Best Buy.
Thank you very much for your help.
Brian -
btrotter - I have the DVP-642 and it most definitely supports DTS, but only in pass through mode. There is no DTS decoder, so you will need a receiver capable of decoding the raw DTS stream it can output. My DVP-642 has worked like a champ for me for almost a year and a half, but some have complained of problems with this model.
Originally Posted by jman98
Looks like I just found my next DVD player.
Thank you!!
players for UK, ntsc or multi-region
By mbernard in forum Newbie / General discussionsReplies: 2Last Post: 27th Jul 2010, 09:53 -
Multi-Region DVD Players
By zork152 in forum DVD & Blu-ray PlayersReplies: 17Last Post: 17th Oct 2008, 12:57 -
Multi-Region Hacks for SD DVD Playback Using Blu-ray Players
By Big C in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Jul 2008, 18:27 -
WMV capable multi-region DVD Player
By siluet in forum DVD & Blu-ray PlayersReplies: 13Last Post: 24th Sep 2007, 08:42 -
multi-region portable dvd players
By mech1 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Jul 2007, 06:36
