    Jan 2001
    New Zealand
    Hi,
    Ive got an avermedia EZCapture card and i used to be able to use it in virtualdub when i was running win98 and win 2000
    now ive upgraded my pc to a intel p4 3ghz 630 and have installed win 2000 and when i go capture in virtualdub it locks up and my win 2000 is a fresh install with all the latest drivers etc...
    then i uninstalled the avermedia drivers and install the btwdm drivers and run virtualdub and still does locks up the computer
    then i finally install avi_io and it captures but you cant change the pal to ntsc for capturing ntsc footage which i could in virtualdub?
    Ive also ran ulead video studio 9 which does not pickup my card
    Im sure i could capture in windows 2000 but dont know why i can now
    thanks for your help
    TurboRunner
    Nov 2005
    might want to try newest v/dub version. Might want to check for latest btw drivers & different versions (think there were 2 or 3 last I checked).
  3. Member The_Doman's Avatar
    Feb 2004
    Netherlands
    I am also still using the BTWINCAP drivers in combination with the great avi_io
    What I remember is you have to setup the desired videostandard when (re)installing the btwincap drivers.
    Jan 2001
    New Zealand
    hi,
    thanks for replying
    my computer has all the drivers uptodate
    my versions of btwincap is 5.3.8
    and the vdub is 1.6.11
    avi_io is the latest only downloaded it a few days ago
    i used to be able to change videostandard in virtualdub under a video setting and now when i click on it it locks my computer
    ill update my comps details
    thanks
    turborunner
