Hi all,
I have a Mac (Powerbook) and I've never been able to play and AVI video file; either from downloading a video from Limewire that was AVI or streaming and AVI video on Windows Media Player.
My friend told me to download VLC Media Player, which I did but it never solved the problem.
What do I need to play AVI files?
Thank you all.![]()
Results 1 to 13 of 13
AVI is a generic term. It's a video file that's not a MPEG, other than that, it doesn't tell you anything.
But if VLC won't play it, it's probably a strange codec or corrupt. VLC plays most anything.
You would get better answers about Mac software in the Mac forum. Moving you. -
Originally Posted by londor
What do I do? -
Edit. Serbian was faster.
Just in case, unzip the component and drop it in:
Macintosh HD / Library / QuickTime -
I downloaded it and then got a message "Safari can't open the file "AC3 Codec.component" because no available application can open it."
First, I would recommed you to turn off the "Open safe files after download" that you can find in the General tab of Safari preferences.
Second you do not need to open the "AC3 Codec.component". Just take that file and drop it in:
Macintosh HD/Library/QuickTime
Once it is there, QuickTime will be able to play AC3 audio. -
I found an avi online, but when I try to play in VLC, I get the message...
main: no suitable decoder module for fourcc `IV50'.
VLC probably does not support this sound or video format.
Is there something that I need to load to play?
jbcandkcI'm just sitting here watching the wheels go round and round.
-John Lennon -
dropped it into quicktime via library and HD but still no sound.
If you dropped the "AC3 Codec.componet" into the QuickTime folder whilst QuickTime was open you need to quit it and re-launch it for the component to work. Do you get sound now?
AVCHD - figure this one out
By cloudxsoldier in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 2nd Aug 2011, 23:05 -
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 22:22 -
can anyone help me figure out why certain files wont play on media player
By DaLoKi in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2010, 14:44 -
data avi .hdtv.avi-fqm.wont play on set top recrder
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2009, 14:55 -
can't figure out Recording to pc
By deadmanrob in forum Newbie / General discussionsReplies: 6Last Post: 9th Sep 2008, 06:56
