Is there a program that authors DVD and/or can save mpeg files to DVD that can also check the integrity of the data on disk after it burns? Someone told me it happens once in a while you think you made a DVD but not really.
Most burning software has a verify function. In my experience they are not worth spit, and produce more false positives than accurate results. Personally, I use DVD Info Pro to test the integrity of my discs, and have been happy with the results.
If you find that you thought you made a DVD, but it turned out you didn't, then you screwed up, and no verification software in the workld will fix it.
Simple rules.
1. Always test in the HDD Before burning
2. If in doubt, test with an RW first
3. DVD Infor Pro or Nero Speed Disc to do a read testRead my blog here.
There are a bunch of file comparison utilities like winmatch or windiff that you can use also, but, if there's a problem, in my experience anyway, it's with the way the data was written, not the data itself, so as gunslinger said.
Authoring .MKV onto a blank Blu-Ray disk
By WBBIRL in forum Authoring (Blu-ray)Replies: 9Last Post: 3rd Oct 2010, 13:06 -
Blu-ray disk authoring: BD player rejects them
By swraman in forum Authoring (Blu-ray)Replies: 16Last Post: 26th Sep 2009, 07:39 -
How to check what authoring programme was used?
By grzegorz in forum Authoring (DVD)Replies: 4Last Post: 4th Dec 2008, 01:26 -
What is the Check Disk Command
By videocheez in forum ComputerReplies: 2Last Post: 19th Oct 2008, 18:27 -
disk check in vista
By shititin in forum ComputerReplies: 5Last Post: 21st Mar 2008, 19:43
