  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Just got myself a JVC dvd recorder and need quality dvd-rw discs from Bestbuy/Compusa/staples.
    I have no idea what brands from these stores would be quality. I have only always used +media made in japan Verbatim (MCC) or Fuji (RICOHJPN). So what brand do I look for with -rw for these stores?
    What We Do In Life, Echoes In Eternity....
  2. When I got my recorder last year I was in the same boat. I had no experience with DVD-RW media. I was in a big hurry - so I looked in the user manual under recommended media. Said Fuji 1-2x and they were sitting right in front of me on the shelf at Bestbuy. Bought a 5 pak and headed home. To my horror - they id'd as RITEKW01. I thought I wasted my money for sure. That was 9 months ago and dozens of uses per disk ago. They are still working much to my surprise.
    I by no means recommend them - just sharing my experience.
  3. Originally Posted by Denvers Dawgs
    I had a hard time finding -RW discs for my Pioneer. Without research I bought some GQ brand 2x DVD-RW's from Fry's Electronics. DVD Identifier says that they are OPTODISCW002. I've been using and rewriting them for over a year now and they still work fine. Of course, if you can find better media then by all means buy it.
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Well I ran to Best buy and all they had for -rw media were the Fuji 2x. So that's what I got. I'll have to check the media ID when I get home. I'll post what I got later...thanks for your replies.
    ***UPDATE***
    Media Code for Fuji 2x dvd-rw is RITEKW01 hope they work out.....
    May 2004
    If you have an H.H.Gregg near you, look for JVC 4x DVD-RW made in Japan by JVC/Victor.
  6. I'd love to find the JVC MIJ media or any DVD-RW MIJ media here in the US. I use Verbatim 4X DVD-RW when I do use it.
