  1. Was attempting to back-up Zathura with dvdfabdecrypt. All went well on the rip. Loaded into Shrink, reduced the menus and extras. Shrink showed a correctly sized file. Resulting dvd video_ts folder shows under 4.5 gigs but when loaded into Nero, it was well above file size limit, something like 4.8.
    Any ideas on how this happened? I double checked all my settings in Shrink to ensure that the file size was correct prior to output.
    Jan 2006
    No idea why it happened but I suggest you burn DVD using ImgBurn (freeware) and bag Nero.
    bits
  3. Member Prot's Avatar
    Dec 2003
    Oregon
    Or you could use DVDShrink to create an ISO file, then burn with DVDDecrypter.
    TANSTAAFL
