I just purchased a Sony RDRGX315 and even when recording in the HQ mode it looks like it either doesn't record all the frames or drops some when playing back from the recorded disk. I'm using the front s-video input.
I haven't found anything in the setup that would help.
Does anyone know what could be causing the jittery playback and/or what could be done to eliminate it?
Thanks for any help.
Effer
Nope. I'm recording from a Dish Network 811 rec'vr.
I was using the s-video output/input thinking the pic quality would be better than from composite. -
Yes it could be but I knbow there can be issues with s video
See https://forum.videohelp.com/viewtopic.php?t=292487
Someone who knows more about it than me may be along soon to help!
Try it to see if it eliminates the problem as you are feeding the dvdr a different signal. But it may of course be something else like a faulty unit! -
Update - For some reason the jitters are only when the Progressive Scan feature on the RDRGX315 is turned on. When I turn it off the jitters disappear. My tv is a Toshiba 42h83 which i believe has a 540p native display. I'm using the Component connection. Is the problem in the upconvertion going from 480p to the 540p?
JVC SR-S388E S-VHS playback jittery + B&W, diagnosis?
By kbbbb in forum Capturing and VCRReplies: 3Last Post: 5th Jan 2012, 21:23 -
Jittery Flickering!
By Soixante in forum ComputerReplies: 4Last Post: 27th Sep 2010, 07:11 -
Cedocida - "Jittery" playback on some media players/DVD players
By BertRito in forum Newbie / General discussionsReplies: 11Last Post: 4th Aug 2010, 20:20 -
XviD Encode, Playback is Jittery ~ Plz Help!
By Mark-2009 in forum Newbie / General discussionsReplies: 10Last Post: 24th Feb 2009, 12:06 -
Divx (avi container) issues, jittery playback
By adam1972 in forum Blu-ray RippingReplies: 1Last Post: 19th Jun 2008, 19:46
