Hi all Pros,
I Have had this recorder for more than 3 months. So far, I'm very happy with it. But something just happened last night.
I have a dvd-rw movie which was done from computer and I tried to play it on 2 Panasonic dvd players but could make it then I tried it on DVD-533h and the this was stuck in it. I could not reject the tray at all, even tried to reboot power I got the same problem. The screen keeps saying load.
If anybody has had the same problem, please help me out.
Thanks a milion.![]()
Typically, on CD and DVD drives there is a manual disk tray release on the front panel. It requires a very thin metal rod about the size of a paper clip (which is what I often use). The release mechanism is a hole on the front panel to which the rod is pushed in until the tray is released.
Remove said CD/DVD and then you should be able to repower and move ahead as before.
pioneer dvr-433h stuck on 'load' and can't operate any buttons!!
By Scubatt in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th May 2010, 03:07 -
JVC DVR stuck in loop SOLVED
By iamnotamused in forum DVD & Blu-ray RecordersReplies: 0Last Post: 20th Dec 2009, 22:27 -
DVR-533h Firmware help
By dcbj in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Oct 2009, 08:30 -
Firmware disk for Pioneer DVR-533H
By jjmdtw in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Oct 2008, 06:31 -
My Pioneer DVR-533H-S won't record DVDs or finalize them!
By superman123x in forum DVD & Blu-ray RecordersReplies: 4Last Post: 31st Jul 2008, 18:22
