Hi There..
I wanna know the right way and the right software to rip my audio cds
into .ac3 files without losing any quality (you know what I mean..I want the .ac3 files to sound exactly like the audio cd) and no matter what the size is..
So I was thinking of ripping my audio cd into .wav files using Sony Sound Forge then using ffmpeggui to convert the .wav to .ac3 with the highest birates..
So is this way working with what I want..or there's another better way to get a highest quality..
Thanks In Advance..
CAESAR
Results 1 to 22 of 22
you can't , ac3 is a lossy compressed format - so it will never sound exactly alike (if fact - quite a bit gets thrown out)
the highest quality would be to leave as pcm files - or one of the lossless compressed audio formats ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Yeah, transparency would be a better target. ffmpeg AC3 encoder isn't tuned so you would probably get better quality with another encoder. Still at a high bitrate it is probably ok. None of us can tell what is transparent to you though. You would simply have to ABX to determine what bitrate, if any is transparent.
Do you mean ".MP3" audio files? MP3 audio is also a lossy format.
If you want the highest quality, then keep the original .WAV format.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Well could you please tell me what software to use to convert an audio cd to to PCM files and keep the audio quality like BJ_M has just said..
Hi, with wav (pcm) to either ac3 or dts conversion, you always will have a data loss.
If you want to place more than 1 audio cd to 1 DVD in original quality, the best way is to use a programme, which is able to creat an Audio DVD with the use of orignal PCM format without conversion. On a single layer DVD about 6 cd audio discs.
I don't wanna place here any name, but you have to search on the web...
Yes, sometime CDex lies about "perfect rips".
Secure audio extraction : CDex full paranoia versus EAC secure mode
-drjOriginally Posted by HydrogenaudioThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Thanks! That's "exactly" what I was asking, I guess I'll try to work my mind around EAC at last...Originally Posted by drjtech
comment on this test:
this test is 4 years old and had be done on a historic drive
Iīve found no hints to the version numbers of each program tested there. In every case itīs no actual version, many things might change in nowadays versions
sound forge and vegas also do damm good audio rips of cd's also ... but EAC is very very good ... but on todays faster systems - i never seem to have a problem with cdex either
Hi guys...Thanks for advicing me to use EAC..
but it didn't gave me a 48 KHz wav files that I need in DVD Lab-Pro..I've looked in the compression options in the Microsoft PCM Converter wave format but the maximum sample format was 44.100 KHz which is not acceptable in DVD Lab-Pro..
so I'm sure I'm doing something stupid :P
can you tell me what option I've to change to get the 48 KHz in EAC..
THANKS IN ADVANCE..
CAESAR -
You don't change ANY options in EAC (or whatever ripping software you're using).
1st- You rip to LPCM/WAV (16bit, stereo, 44100Hz)
2nd- You take that WAVE file and Sample Rate Convert it (upsample) to 48000Hz.
3rd- Now, you can use it in most any DVD authoring app.
What app to do SRC with? SSRC is a good one (and free).
How we can remove commercials from a video cd without loosing quality.
By nusratjaveid in forum EditingReplies: 1Last Post: 4th Dec 2010, 11:17 -
remove a logo without loosing quality
By mathmax in forum DVD RippingReplies: 13Last Post: 9th Jul 2010, 12:54 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Joining Xvid files with MP3 audio (VBR) without loosing synch?
By fk in forum EditingReplies: 6Last Post: 31st Jul 2007, 20:19 -
Importing .PSD files into Dvd Lab Pro, and loosing image quality.
By mlong30 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 20:28
