I have come back to SVCD2DVD after a bit if a break. I'd forgotten how useful it is!
I am capturing DVB-T here in the UK. I use VideoReDo to edit/remove ads etc, and use SVCD2DVD to burn these catures to DVD - and it works a treat. My only fly in the ointment is that I no longer have audio when I do a preview. It use to be there, until I got adventurous and used the slider control to move around the video. Since then, no audio!
I have tried a re-install, to no avail.
What else is there for me to try? All (legal and/or anthropologically possible!) ideas welcome...
Andy E.
The preview uses WMP essentially . Does the assets play in WMP? What is the audio AC3?
Mmm. It plays (with audio) in WMP but not in the preview? Thats a first. Can you use the makesample tool in the tool folder to send me via email a small clip which illustrates this?
Comin' your way!
Cheers.
PS I forgot the makesample tool 8-(
It's only a couple of meg tho' If you particularly need it done this way, give me the nod and it shall be done! -
Ok. Thanks. I have sent you a newer build to try as it works fine for me at this end...
VirtualDub doesn't play audio in preview
By Sebastian2011 in forum EditingReplies: 20Last Post: 19th Mar 2012, 04:33 -
DVD Audio Extractor can't listen audio preview
By lupio in forum AudioReplies: 8Last Post: 26th Apr 2010, 11:51 -
No audio in preview or output MPG file in VOB2MPG 2.0
By scruzphreak in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jul 2009, 12:20 -
Movie maker -- no audio during preview
By mister in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 9th Jun 2009, 12:41 -
audio cuts out randomly during NLE preview
By maxtrack in forum AudioReplies: 5Last Post: 22nd Sep 2007, 07:16
