Hello
i want to create a simple avi clip having my name in it ..
so i can put that in my video DVD before menu
coz i have figured that my dvd player cant play Video DVD in which ther is no starting clip
let me make that simple..
i want to add a clip which reads "This DVD is Authored by ---EnLi--- "
which should b around 30 secs length with some nice audio
Can u do That for me ?
Or just tell me software in which i can do this
I would b glad to hear from u guys
Thx
Results 1 to 13 of 13
Even better still (sorry guns1inger), create the wording how you like it in MS Paint and save as a bitmap.
Then use this bitmap as your video source in your encoder, and add any audio that runs for 30 seconds, even if it's silence.
If you do use silence, only output the video aspect - it'll still run for 30 seconds and you'll get an M2V file.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
thx for replys
can u make that AVI file with nice audio for me ?
Title Should Read:
This DVD is authored by ---EnLi---
Should b atleast 30 secs length
Thx very much -
This is a forum where people offer advice and help with problems, not offer services.Originally Posted by enli2
You've got Win XP - that comes with MS Paint and Windows Movie Maker, depending on which solution you choose to use.
Either way, you need an encoder that'll take your input (either a picture file or an AVI file) and encode it to MPEG2 if you want it to be on a DVD.
Look in the "Tools" section for encoders. There are some free ones.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I think you guys are trying to help solve a problem that doesn't exist:
There could be lots of reasons why his DVDs don't play, but the lack of an intro/startup clip isn't one of them, I don't think.
So enli2, when you put retail DVDs into the player, they don't play? Maybe it would be better for you to explain just how you create these unplayable DVDs, and then maybe someone can show you a better way. -
well i created 2 dvds with DVD author
The 1st i made without menus worked well on my dvd player
but the second in which i have added menu and chose "display main menu"after disk inserted in the player ....that 1 doesnt work at all
player shows VCD and then on screen it dispays "STOP"
So i guess that i need to use some movie track and chose
play first track after disk inserted ...i think that might solve my problem
Sry for my poor english
Thx -
Hi-
Nah, there's nothing wrong with your English. It's your deductive reasoning that I think is flawed.
You mentioned DVD Author, but that's not specific enough. I guess you mean TMPGEnc DVD Author (TDA), but it could also mean GUI For DVDAuthor, or DVDAuthorGUI, or by extension, any authoring program.
But I won't be able to help much. The only one of those I've used when creating a menu is DVDAuthorGUI. There are plenty of TDA experts on this board, though. When reencoding and keeping the original menu from the retail DVD, there's no better way than the "Replace" button in VobBlanker. But if it was TDA you meant, there are quite a few guides for its use on this site:
https://www.videohelp.com/guides.php?tools=181&madeby=&formatconversionselect=&howtosel...or+List+Guides -
hi
i have got 2 mov files which i want to convert to avi ---- (file x1)
then join them and add a sound for the output ----- (file x2)
then join the output avi with the avi file which i have explorted from swishmax project -----(file x2)
But getting error"The Video streams have different formats"
when i try to join these files
What i did:
Used TMPGEnc 3.0 XPress to convert mov files to avi and automatically join them
then i added audio to the output file from TMPGEnc 3.0 XPress---- (file x4)
then i added video to file x2 ----- (file x5)
Then i tried to join filex4 and file x4....
but getting errr "The Video streams have different formats"
Plz help fast n tell me what softs i should use
n if possible tell me the procedure
Thx very much -
Well, I wouldn't mind trying to help, but I think this thread has taken a 90 degree turn now. Wasn't it about his DVDs that wouldn't play in his player? But now it seems to have switched to a mov->avi and joining thread, something I, for one, have no interest in.
Like the good man said, read and learn. Good luck. -
oh welll
i ll try to search
Now my DVd plays in my player
what i did in tmg.. dvd author that
i used play first track when dvd is inserted in dvd player
Before that i didnt use that n my dvd player was not able to read that ( it showed VCD when i inserted dvd in that )
Thx Very much for all the help i have got
