Hope someone can help me out here.....i decided to wipe my pc and reinstall my OS(win2k pro)...had my card working fine before i did a clean install....i have my card working fine (prv150) except for 1 thing....before i had it setup to put my recorded shows on my other drive as well as the pause feature but when i try to set it up now all it will show me is my c drive...i even tried changing it in the registry and it still doesn,t work...i ran into this problem before and it was something was disabled in the startup munu but this time there is nothing disabled...any idea where i can start to trouble shoot?...been workin on this fro about 3 days now with no luck
Can you see the other drive from Explorer?
I've seen drives disappear because they were assigned a drive letter manually, then on a reinstall (or moving a drive from one computer to another) another drive (or DVD drive) is using that letter. The solution is to assign the other drive to a different letter (at least teporarily) so you can see the original drive. -
the drive shows up everywhere else except under the wintv dropdown menu and my other drives (2) also show up everywhere else(cd burner and dvd burner)
Be aware that ms update's can also make change's that user's are unaware off .
I have seen some update's cause many unusual problem's .
Last update I recieved for winxp pro caused dvdauthorgui to think my mpeg's had been split at some stage ... had to re-encode them .
During the reinstall , did you remove the card itself from the pc ?
Almost all of these device's now require the software to be installed first ... then shutdow pc (turn off at power point) ... install device , and power system up ... allow system to detect device and install required drivers from cd supplied with device .
If not ... it's a starting point to most ailment's .
To remove , uninstall all device driver's for this device , then the software supplied with unit ... shutdown pc ... remove device ... restart pc to make sure clean out was effective ... now install correctly as specified by device instruction's .
Also check for software update from site ... and if they have a faq or user forum where you might also find the help you need to discover the problem .
As for re-assigning driver letter's , this is best to be avoided ... some system's have no issue's , but other's will ...
It's a bit like rolling back the xp system to fix problem's ... it can and normally dose cause major headaches . -
yep i removed the card and followed the procedure thats on the hauppauge web site.....i may try xp pro(upgrade) to see if it might fix the problem even thou i hate xp lol...head is starting to hurt from thinking of ways to make this work lol...the drive letters stayed the same as they were before and i,ve uninstalled and reinstalled the card about 6 times with no change
check out my setup and let me know the problem
By thedude4242 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2011, 16:20 -
Setup Hauppauge WinTV PVR-350
By DaveQB in forum LinuxReplies: 9Last Post: 18th Oct 2009, 22:56 -
Foxconn motherboard design setup problem...
By MidnightMike in forum ComputerReplies: 3Last Post: 19th Feb 2009, 10:33 -
Problem with Projector Setup
By Dimava in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2009, 14:41 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
