Hi there,
Im a newbie & this is my first post.
How can I burn some of my home movies on CDs to DVD format?
What software would be needed to get near close vear close DVD video & audio results?
Any help shall be highly appreciated.
TIA,
Regards!
Ivanov Yezinki
Originally Posted by Inanov"Art is making something out of nothing and selling it." - Frank Zappa
Your asking about making your videos on CDR right? You want to make a VCD or SVCD.
Need to read one of the basic how to's like,
https://www.videohelp.com/forum/userguides/94288.php -
As long as they are actually VCD's you can import them to TDA and put quite a few to a single dvdr.
But as ZippyP. said, that will not make it dvd quality.
VCD = Mpeg 1 352 x 240 - 44100 Hz Audio
DVD = MPEG2 720 x 480 - 48000 Hz Audio
Re-encoding it to dvd specs will NOT improve quality, you can't add what's not there
TDA should convert the audio from 44 to 48.
All you have to do is rip the video from the vcd to your HDD with something like vcdgear, Isobuster.
Inport it to TDA, make Menus, ect. and author then burn. -
Originally Posted by Noahtuck
Originally Posted by akrako1
And you don't have to do any converting, as i said, TDA will convert the audio from 44 to 48.
So you don't have to do any converting before loading into TDA, TDA does it.
powerpoint conversion to VCD
By Kratz in forum Video ConversionReplies: 2Last Post: 19th Feb 2010, 14:16 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
WMV to DVD or VCD Conversion
By MannyNoela in forum Video ConversionReplies: 9Last Post: 6th Feb 2008, 10:22
