I have lots of TV series on VCD that I want to combine to DVD's. I just spent several hours reading authoring guides, downloaded several trials... and like the ease of TMPGEnc DVD Author,...but it locks up on last step (goes like 2-3% then says Error at #### and quits) ...thought this was due to running 98 but locks up on my Win2000 machine also, any sugestions on what to try? Or even sugestions on programs that create menus and have a free trial?
Results 1 to 9 of 9
I know TDA is not guaranteed to run on W98, but W2000 should have no problems. With W98 the FAT32 file system is somewhat of a limitation anyway.
You could try the trial version of DVD-Lab. A little more complex than TDA, though. Or the freeware DVDAuthorGUI. Both will do what you need. -
Actually VCD video is within dvd specs, the audio is not but TDA should accept it and convert it from 44 to 48.
I have put tons of vcd's to dvd with TDA.
Otherwise pretty much what redwudz said.
from your specs you should be able to run WinXP no problem. -
VCD's in spec do not have 48khz so somewhere along the line the audio must have been converted otherwise they were not true VCD's.Originally Posted by MaDmiZe
Well as much as I am opposed to it, I guess I'll start backing up the hard drive for a clean install of XP. Then we will see if it works...though I am more than sure that I will lose some of the other programs that are working now. Thanks for the sugestions...anyone else who has had these problems...check with me in a couple days to see if any thing works : )
Well guys, that didn't do it. No better with XP. Using full version of TMPG DVD author 1.6. I need to write down exactly what it says....but when you go to output...goes like 2% and says error at #### then quits. VCDs have were non-standard and converted back from dat to mpg. Audio was and is 48khz.
trying to make Microsoft Home Publishing 2000 work on Windows 7
By LadyTaz in forum ProgrammingReplies: 2Last Post: 12th Jul 2011, 21:16 -
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
TmpGenc Authoring Work Shop 4
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 1st Apr 2010, 19:43 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Does TMPGenc Plus 2.5 work on Vista Ok?
By leegutcher in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2007, 08:22
