I have been using vso convertxtoDvd for all my .avi's and .divx files, but now I have a few .rmvb files. Is there an easy way to convert them to straight to DVD without converting to .avi? Cause I tried that first, and it turned a 175Mb file into a 2.1Gb avi. So, quick and easy? Anyone?
Tried WinAvi6.3 and it gave me skippy delayed sound.
You guys are brilliant, so if there is an easy way, I'm sure you guys know what it is. Thanks for any help.
Results 1 to 11 of 11
I must say for rmvb to mpeg, author and burn with no sync problems I suggest eo video
http://www.eo-video.com/download/download.htm
just my 2cents -
Ok, I tried Super - File had no sound. What settings should I use for rmvb to dvd?
I know file size increases. When I convert an .avi to dvd with vsoconvertxtodvd to goes from 300Mb. to about 800-900Mb. And using DVD shrink I can still fit like 8 or 98 episodes on one disk. But with Winavi, the rmvb was only halfway done and was up to 2GB, oh and the running time is about 40min per episode.
And I don't know how to use EO Video. Can you give me the settings I need? -
I tried latest version of VSO Convertxtodvd, but it said that my
RMVB file was an unknown/unsupported format.
I tried latest EO Video. After more than two hours, it had made its way through the first 15 minutes of my RMVB file.
What else is there? -
Real Alternative to allow Avisynth to load the video as a direct show source, then frameserve this to any encoder. You will have to uninstall Real PLayer to use real alternative.
Read my blog here.
The best and easiest solution is use gabest's real media splitter. It is part of Real Alternative. If you have RealPlayer installed, you don't need to uninstall realplayer and install the whole real alternative. You only need to install RealMediaSplitter.ax by typing at DOS prompt:
regsvr32 RealMediaSplitter.ax.
(for uninstall, type regsvr32 /u RealMediaSplitter.ax)
Now you can open rmvb files in TMPGenc, without using a frame server. If you use CCE or other encoders, you need to use Avisynth as frame server.My favorite online storage for image, audio and video files:
www.myFileHut.com is #1 for Free File and Image Hosting -
We have several guides on converting RMVB, and I wrote one of them.
https://forum.videohelp.com/viewtopic.php?t=289872
Just substitute an MPEG encoder (TMPGEnc Plus works well with AVISynth) for VirtualDub.
4:3 and 16:9 on same DVD - solution
By sergem1 in forum Authoring (DVD)Replies: 6Last Post: 15th Jan 2010, 02:03 -
Extremely easy backup solution.
By Poppa_Meth in forum ComputerReplies: 9Last Post: 19th Nov 2008, 10:14 -
RMVB to DVD...no audio?
By Tiramisue in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 19:09 -
rmvb to dvd?
By asdfprou in forum Newbie / General discussionsReplies: 8Last Post: 29th Nov 2007, 01:20 -
Need an easy all-in-one DV to DVD solution
By kyroha in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2007, 07:16
