when i tried converting some .m4v's (the default iPod setting on iMovie), it only lets me put it in a few formats. i want to put it into an ipod format and it wont let me![]()
thanks.
Results 1 to 10 of 10
Try to send me a clip to major4@mac.com for testing (you may use yousendit.com to send files).
Yes, I dropped it on ffmpegX, then selected target format "iPod H.264", clicked Encode, and it encoded a working MP4 file.
What is .m4v?
By kevs in forum MacReplies: 8Last Post: 17th Jul 2011, 13:20 -
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 17:15 -
m4v to dvd
By thecrock in forum Newbie / General discussionsReplies: 8Last Post: 14th Aug 2010, 02:32 -
m4v to DV
By jscape2000 in forum MacReplies: 3Last Post: 3rd Dec 2009, 13:41 -
a few m4v files have no audio when playing in iTunes...work fine in qt/vlc
By bobogs in forum DVD RippingReplies: 0Last Post: 18th May 2009, 21:21
) is there a way to make the file exactly the same quality as the original, or is that impossible? my original is extremelly clear, and the .MP4 file is pixelated, not as clear, dark, etc.
