Hello-
I am trying to convert AVI to VCD. Using TMPGEnc, I have loaded the VideoCD (NTSCFilm) format to create the mpg file, but when I create my video cd with Easy CD Creator 5 Platinum, the VCD's do not work in a DVD player with the VideoCD icon...
I did notice that under the details on the avi file, it shows the fps at 14.985 instead of the standards that I've read in conversion guides...
Can anyone help me?
Thank you.
Mikemillion
well i don't know if this'll help but, i use nero 5.X and it works fine on my dvd player. try using it and see the result.
uneek, is a unique way of spelling it. -
Thanx for the info, but that (using Nero) did not work either. I was actually using nero before I started using Easy CD creator
I'm curious as to how it "got by" the screening process that Adaptec/Roxio uses.(ie:when you add your file to the list..the window comes up saying whether all your settings are VCD compliant)??
Did you have any ..!!!!! (exclamations marks)
and I'm guessing that you could'nt have had any xxxx..
because it would'nt allow the burn proces to start. -
Well, I did not note any messages that you are speaking of, but I did do a search on this forum, and found a possible solution..
Setting the framerate to 2x, which I perceived as using the setting for 29.97fps in TMPGEnc... I will recreate the VCD after I do this conversion is complete and see if it works..
I'll keep you guys posted on my progress..
Mike -
I found that Easy Cd seems to like files encoded with AVI2MPG rather than anything else
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 19:52 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 06:42 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 12:05
