The only thing I can think of is as follows :
Extract the audio as previously discussed, to an uncompressed wav file.
Open the avi file in Virtualdubmod, then go Streams->Stream List. Click Add, and add your wav file. Right-click on the mp3 audio track and click disable. Click OK.
Play back the video and look at how far out of sync it is, and whether or not is starts to early or too late.
Go back to the streams list. Right-click on the wav audio track and select Interleaving. In the section marked Audio Skew correction change the value in the Delay Audio Track by field. Click OK/OK and test. Repeat this until your audio is in sync. Save this out as a new avi (Direct Stream Processing mode for both video and audio), then use this new version in ConvertXtoDVD.
Results 31 to 31 of 31
Read my blog here.
Sound gets irritating while scroling mouse in some internet pages
By Artas1984 in forum AudioReplies: 7Last Post: 2nd Oct 2011, 07:49 -
Easycap v2 - Ulead - audiosync
By Akerhage in forum Capturing and VCRReplies: 8Last Post: 22nd Jul 2011, 05:48 -
Bad Xvid Encoding - forgotten deinterlace- Is there any way to fix it ?
By Womb4T in forum Video ConversionReplies: 1Last Post: 18th Dec 2010, 18:56 -
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
Irritating problem (flashing vertical bars)
By weko in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2008, 07:40
