I'm not asking about my DVD Player and what works with it but...
Can DVD Players (in general) play MPGs? I want to convert some DivX movies to "VCD" like I've done for my DreamCast and they are .mpg Can any DVD Players play them?
Also how do I get them to play? Do they load automatically?
Thanks for answering these!!
All DVD players play MEPG movies - DVD movies are MPEG2 encoded after all. However, the mpegs have to be acceptable to the player. If the mpeg is encoded any other way than what the player will accept as playable (in that the bitrate and resolution is in acceptable parameters etc.), then it wont play it. I beleive that some players can play straight .mpg files (not burned as VCD/SVCD), dont ask me which ones though. Anyways, the .mpg still has to be acceptable to the player even if it will play .mpgs straight off a non standard burnt disk. Divx encoded videos will not play, you will have to convert to a VCD compliant .mpg.
In most cases you will have to burn the correct format CD as well (Ie. VCD/SVCD). You cant just get any old .mpg and burn it as a CDROM and expect it to play.
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 17:00 -
Some Simple AviDemux Questions - iPhone video
By hech54 in forum Video ConversionReplies: 9Last Post: 27th Oct 2011, 10:45 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
New to video making. I have a few simple (I hope) questions.
By BornRuffian in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2009, 01:01 -
Some simple questions about Dreambox and HTPC
By Talayero in forum DVB / IPTVReplies: 0Last Post: 8th Apr 2009, 12:44
