    Feb 2003
    Alright, this is my first time authoring with DVD-Lab pro (3.0.0.170). I wanted to include 2 audio tracks for 1 video, and figured this was the easiest way to do it. I made a VERY basic menu- there's only one title, no chapters, and 2 audio tracks. I put a background on my menu, created a button pointed to audio track 1, another button pointed to audio track 2, and another button pointed to play the title. That's it. It compiles just fine. When I play the disc on my dvd player, I choose the audio track I want, then select play. It starts playing fine, then after about 10 seconds, goes back to the menu. What's going on?
    Feb 2003
    c'mon... somebody must have had this problem...
  3. Can't say I have seen this problem with my DLP authoring.
    Let's decompose the problem:
    - Recompile without any audio just the video stream. Does it still die with 10s?
    - If yes, Does the video play fine outside DLP? If no, then go back to the source and convert again.
    - If no, try one stream at a time and repeat. Does one stream (or both) cause the video to stop within 10s?
    There is a reason why God gave us one mouth and two ears!!!
    Feb 2003
    The audio and video tracks are just fine. I'm able to author with TDA with the video track, and either audio track. The resulting disc is playable.
    I will attempt to recompile with DLP with 0, then 1 audio track. I will post the results. Thanks.
    Nov 2005
    Try leaving the audio buttons off, add each audio track to the movie -- with the movie window open, drag one then the other audio so you show 2 tracks below the video. Use the remote to switch audio tracks. Read the DLP docs for info on menu switching audio if you want to later go that route.
