I understand the Wide Screen format with the black bar on top and bottom, but whats with some of the movie rentals that I receive with the two large black bars that take up half of the screen??
Do you have a widescreen tv? That could be a full screen dvd that isn't taking up the full screen.
A little more info might help us give you some direction on this.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Maybe he's referring to the ulta-widescreen CinemaScope (?), ie: 2.35:1? (while viewing on a 4:3 monitor presumably)
Not all dvd player's are made the same .
Example title : alien's vs predator
Centrex - normal small black bar's
Hyundia - normal
Pioneer - normal
Xms888 - abnormal , large black bar's
Then there is unusual menu behavior .
Centrex - played whaling station history , stationary menu
Hyundia - same , played motion menu
Pioneer - no history clip , motion menu
Xms888 - similar to flash back to and fro , static menu .
Centrex - zoom mode (number stay's on screen)
All other's - dissappear's shortly . -
There are different aspect ratios for widescreen, so not all "widescreen" movies will display the same.
The link posted above has some good information.Google is your Friend
Mixing File Formats on One DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jun 2010, 09:17 -
Video formats to dvd
By Illusionist in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2009, 13:51 -
Easiest way to author dvd from other formats?
By Iwan2learn in forum Authoring (DVD)Replies: 10Last Post: 12th May 2009, 04:03 -
TMPGEnc DVD AUTHOR and other movie formats
By loa909 in forum Newbie / General discussionsReplies: 3Last Post: 4th Apr 2008, 06:19 -
DVD Formats
By Bluenote58 in forum MediaReplies: 9Last Post: 30th Sep 2007, 06:23
