Hi,
I've just started to use the Canopus Procoder for converting dvds from PAL to NTSC.
It seems to do a good job.
My problem is with authoring though.
I have been using TMPGenc Video Author for some time, but when I import files created with Canopus, I keep getting the message 'video sequence header required'.
It seems I should alter one of the settings in Canopus.
If anyone has the answer, please let me know.
H E L P
if you use a dvd template - it is automatically selected ..
if you dont (but you should) , check off 'add seq. header to each GOP'
you can see this if you hit advanced -- this btw, is covered in the excellent manual you got with procoder"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Canopus Procoder: chapters in DVD-export? How?
By Lippy Lipstick in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2008, 06:09 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 04:07 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 08:56 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 22:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 22:25
