  1. Member nbarzgar's Avatar
    Sep 2004
    Austria
    Hello,
    last night I had a Rebuilder project running, but had to abort it without being able to save the project first. All .tmp/.ini-files etc. are there.
    Since the project has been ~70 % finished I wonder, if I could recover it although no project file was saved?
    Help would be very much appreciated!
    Apr 2004
    Miskatonic U
    Try taking it off one-click mode, then starting it again in the encode section. I would take a copy of the folder first in case it starts again.
    Read my blog here.
  3. Member nbarzgar's Avatar
    Sep 2004
    Austria
    Thanks a lot for the fast reply. Did as you suggested:
    'One-click mode' off, then restart programme, press "encode" - then got a pop-up telling me, 'last encoding process had apprently been broken off, did I want to restart from last successful encode?' "Yes"/"No" - I chose "yes" and DVD-RB immediately opened encoder.
    It is now working, looks fine so far.
    Apr 2004
    Miskatonic U
    Glad to hear it. Hopefully it completes without interruption this time.
    Read my blog here.
  5. Member nbarzgar's Avatar
    Sep 2004
    Austria
    Finished without a hitch! Just had to press "Rebuild" after encoding was over.
    Am completely happy about it!
    EDIT: First process-abortion was due to necessity, did it manually, no fault of DVD-RB. EDIT
