Easily fixed. Added the comctl32 activeX component to the installer. Also packaged with this version is the sourcecode. (which I finally found)
https://www.videohelp.com/~liquid217/Multi-Synth_1.001.exe
Results 61 to 90 of 101
Hi there!
New release - first BETA.
Please note... this is the FIRST BETA - USE IT CAREFULLY and please use empty folders for tests (just in case, I tried to add warnings every time something is going to be deleted but...)
here's the change log:
Please note: The Encoding feature will work (at this point) with MPEG files ONLY!!! and you can only use HC to encode the Video and QuEnc to encode the Audio.++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++
01 MAR. 2006 Alpha2
-Changed the ridiculous violet (on CRT monitors) colors. It's a little grey now, that means I'll change it again, later
-Fixed several annoying and stupid bugs found by several testers - my thanks to Archeo and Feedback from doom9 forum and Daamon, Dipstick, Guns1inger and Compuser from VideoHelp forum.
-Added the possibility to change the Start and End cut points of the previously selected segments;
-Added the "Save Project" and "Load Project" feature.
14 MAR. 2006 v0.1.0 Beta
-Updated the "Up" and "Down" segments move. Now the selected segment keeps 'highlighted' - my thank goes to communist (doom9 forum) for remembering me about this;
-Added support to "Video(only)Streams" - .m2v and .mpv
-Fixed a bug that related to target frame size on the import dialog - if a target size was chosen before selecting a file you would get an error and program would close;
-When saving a Project, SynthEditor will check if the selected folder contains files... if it does a warning will be shown telling user that those files will be erased - user can choose to continue or not... sorry about your files niiyan (doom9's forum)
-When closing the program will be asked if user wants to erase all the temporary files;
-Corrected a few bugs on the "Save Project" feature;
-Corrected the display of Frame Sizes on some AVI files (Uncompressed and DV) using AvInfo - all the other data is still collected with MediaInfo.exe;
-Added a routine that is supposed to detect frame type (progressive/interlaced) and Field Order, from mpeg files, using DGIndex and an AutoIt script;
-Added the encoding Feature for MPEG Files (ONLY!!!) - on this release you'll be able to encode video using HC Encoder and QuEnc will be used to encode the audio.
I'm releasing it as it is so you can test the final sizes accuracy, I'll be adding new Encoders (QuEnc for video, CCE - this one is the pain due versions differences and maybe other by request).
Please... be patient... my free time ain't much so I only had time to test it on the same system(computer) I use to program... that means that everything may be just fine here but it may not even start on your computer
Any doubts... just ask, ok?
Thank you all in advance.
You can get it here: http://homepage.oniduo.pt/ROCKAS/My oppinions may change, but not the fact that I am right!
www.rockassoftware.pt.vu
DAudioK => https://forum.videohelp.com/viewtopic.php?t=306886
DVD Rebuilder
http://dvd-rb.dvd2go.org
http://www.jdobbs.com -
DVD Rebuilder
I always forget about that... Thanks Baldrick... I'll add it on the next release.
In the mean time you can download it from here:
http://www.ascentive.com/support/new/images/lib/COMDLG32.OCX
all you need is to put it in the same folder as SynthEditor.exeMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
Typical developer...Originally Posted by Rockas
Poor Configuration Management Control...
Write a list of all of the components, and their version numbers. Be strict enough to make sure that everything on the list is ticked off before releasing it...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
yes I know (we are always in a hurry)... but please remember.. we are talking about betas here
I hope that the list will be complete for version 1.0.0
thanksMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
Yes you are right too... but daamon is great... I think he managed to find all the bugs of my first alpha and he sent me a full report about them... there should be more people like him on th world.
thanks Daamon
DVD Rebuilder
Touché, mon ami...Originally Posted by jimmalenko
Absolutely!!!
Yeah, too right. Pop that in your pipe and smoke it, Scotty boy!!!Originally Posted by Rockas
It makes a change to work on some freeware that actually gets put out to the public, not just having one's efforts appreciated... Come on jimmalenko, take the bait and get "ABC" sorted and released.
"What's ABC?" I hear all the users of VH cry... I'm saying nothing, suffice to say that it's a rocking little utility that's better than only one thing (that I know of) that's out there for batch encoding audio files. All questions, queries, and requests for the final software to jimmalenko
No. I thank you!!! You're quote is going in my CV (resumé)!Originally Posted by Rockas
Carpe diem.
You left me curious... the input and output formats will be?"What's ABC?" I hear all the users of VH cry... I'm saying nothing, suffice to say that it's a rocking little utility that's better than only one thing (that I know of) that's out there for batch encoding audio filesMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
Wow!
Sounds cool, when we gonna see it...? :P
Carpe diem.
And what are the file format options for input and output?Originally Posted by jimmalenkoMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
Are you still developing that tool?
DVD Rebuilder
Was it that bad!
Just kidding... now... why don't you finish it?
if you want to... I can give you some tips that will probably make your work a lot easier
DVD Rebuilder
Are you just using FFMpeg?
DVD Rebuilder
Yep .... all the inspiration came from ffmpeggui which is simple and great ..... but not able to batch process. It's as I said before ..... ffmpeggui with batch functionality.Originally Posted by Rockas
Thanks for the offer. Not to be rude but I think I'll be OK
If in doubt, Google it. -
Not at all. In fact - far from it. There were a few things initially, but it go to the point where it was usable but with some obvious, if not too annoying, bugs.Originally Posted by Rockas
I'm a professional software tester, so gave the software a hard time and fed back everything - including some suggestions for improvements. I'd say address a few points and it'd be good to go - it's close to getting over the line in the state I last saw.
I also have a vain motivation - I came up with the name and some blurb...
"Audio Batch Converter (or "ABC") is a utility inspired by the very popular ffmpeggui, and still uses ffmpeg at its core. This tool takes ffmpeggui one step further by providing a GUI with functionality that enables the user to do batch encoding from[list formats here] to both AC3 and MP2 (still only 2 channel for both).
The user can still do single file encoding, but also:
* Add more than one file to a batch-list for batch encoding.
* Each file can have it's own parameters (i.e. one file can be MP3 to AC3 @ 192kbps and 48,000Hz, whilst another can be WAV to MP2 @ 128kbps and 44,100Hz).
* Batches can be saved and reloaded.
* Set default input, output and batch directories.
* Set default settings for format (AC3 / MP2), sample rate (44,100 or 48,000 Hz) and bitrate.
* Edit the current batch list.
Using the tool is simple:
A. Load your source file(s).
B. Choose your encoding parameters.
C. Encode your file(s).
It's as easy as "ABC"..."There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I'd buy it...!!!
Carpe diem.
You need to get that warning issue fixed ... and I mean it .
How the ??? , when my program's that I am currently writing save stuff , they dont go out and delete entire folder content's , they just save there own file's as required during output .
Bad programing there ... should have been shot for that . -
I'm sorry... I think I put all the warnings necessary on the latest release... did I miss any situation?Originally Posted by Bjs
Thank youMy oppinions may change, but not the fact that I am right!
DVD Rebuilder
New Release
24 MAR. 2006 v0.1.1 Beta
-Fixed a bug on the "Encode Video Only" routine (the bitrate could be badly calculated)
-Added video Encoding using QuEnc;
-Now the selected Encoder will be saved along with the "project file"
-Added a "Target Format" option -- this is important. Make your choice based in what you will be doing with the final file. If you choose "Generic MPEG" the BitRate will be calculated to fit the exact final target size. If you choose "DVD" the BitRate will be smaller to make room for DVD packetizing and NAVPACK overhead. This option will be saved on the project file.
-Now when Frame Type is detected/selected as "Progressive" Field Order is disabled/ignored.
-AvInfo no longer needed... I was using AvInfo to deal with DV and Uncompressed AVI files' Frame sizes... I coded internal routines to deal with those kind of streams.
-MediaInfo.exe no longer needed... now SynthEditor works with a mediainfo.dll included on the package.
-Added a "Force Aspect Ratio" option on the Import Dialog
-Added a "channel mapping" routine when dealing with 5.1AC3 files - thanks for the tip dragongodz and tebasuna51 (doom9 forum)
-You can now use AVI files with wav audio format... please note... WAV audio... I'm working on mp3 yet
-Added a AmplifyDB(9) on the Audio script to compensate QuEnc's "loss on audio level" encode... my thanks to Ebobtron for remembering of it
-Corrected the MaxBitrate parameter... now SynthEditor will subtract the Audio Bitrate to the MaxBitrate.
-Fixed a few more minor bugs
you can get it at http://homepage.oniduo.pt/ROCKAS/My oppinions may change, but not the fact that I am right!
DVD Rebuilder
I'm still getting a warning from McAfee that the "DeleteFolder" method is being called, only now it occurs after I select a video file.
I went ahead and allowed the script to run, and it doesn't seem to have caused any negative effect so I tried a test. It worked OK and is a good start, but you need to include all of the QuEnc options when configuring to encode. It did not use the settings I would have selected. I would like to be able to review the command line that is being used to initiate QuEnc to make sure it is addressing all of the settings because any settings not specifically addressed in the command line are taken from the last time QuEnc was used manually, which may not be appropriate to the current project."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Let's go step by step
The "delete folder script" doesn't harm anything on your system... it is applied on the SynthEditor's "temp" folder... that's all... I just made it that way 'cause when you save a project, SE will copy the files from the temp to the chosen folder... so I want to make sure that will be no unneeded files in it.... anyway... I think MCAfee must review their detection methods... If a folder is created by an app inside its installation folder what harm can it make if that folder is cleared up?
... I think that MCAfee is the only one sending the warning
You can find QuEnc Options on the Setup dialog under menu options... and no... QuEnc will not be using your last settings... it will be using the options on the setup menu - I know... it misses the Matrices stuff, but I was hoping to enable it later 'cause I will include a Matrix Editor (from my Rebuilder's Matrix Editor app) so you can use it to import and use all the custom matrices you want.
Thanks for your tests.My oppinions may change, but not the fact that I am right!
DVD Rebuilder
TSPE beta out! (Editor / Analyser for H.264 / VC-1 / MPEG2 / BD / AVCHD...)
By Ventolin in forum EditingReplies: 124Last Post: 30th Dec 2012, 11:09 -
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 02:06 -
What Video Editor are you using?
By nickmind in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 46Last Post: 9th Oct 2010, 10:58 -
Alternate video codec Pixbend beta launched
By tobytoast in forum Latest Video NewsReplies: 2Last Post: 3rd Oct 2008, 13:37 -
The right video editor
By dgarmaise in forum Authoring (DVD)Replies: 3Last Post: 25th Mar 2008, 14:21
You're giving me ideas now !
