    Jan 2006
    In TMPGEnc - under Advanced, there is a Sharpen Filter - when you open that filter there is a little check-box that you can check or uncheck labeled "field base".....I'd REALLY like to know what this does, what this means or both?
    Please, help me on this - I've searched everywhere to find the answer and have come up with nothing.
  2. It is for interlaced video. If your working with interlaced video you should select that option.
  3. Member j4gg3rr's Avatar
    Nov 2005
    Australia
    I always use it when converting avi to svcd.
    It does a better looking job IMO with it on and less sharpen on edges only.
