What can I do to repair DVDs that are scratched and damaged?
Originally Posted by slam87Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Polish them. There are devices you can use for this, or just use some mild abrasive, like white toothpaste or Brasso polish with a cotton ball. Go crossways, not in line with the 'grooves'.
But I would back up the disc ASAP. -
I dont recommend using such service's , having already esperienced several foul up's .
They setup the machine and walk away ... if machine run's low on fluid , which it can do , your disc's are cooked for good .
The best product's are from wipe out , I personally showed in front of several people a dvd I deliberately scratched with a nail to ruin it , then used 600 grit wet and dry sand paper to remove the scratch , then wipeout to restore the surface to 100% readability ... they couldnt believe it .
This scratch was half the depth of the media , and took around 6 minute's to restore .
The product line is represented by this company in america
http://inkjetrefillkit.net/product.php?product=CD+Scratch+Repair+Kit&lazySID=fvXuBlkjx...cawz1140904916
This is the basic one , I use it all the time with no problem's on cd's or dvd's .
It's what you should go for in your country .
Don't go for those 2in1 product's , there utter garbage . -
I don't know why anyone would want to go to a reseller for Wipe Out just for the priviledge of spending more money. Buy it directly from the company and spend less. Here is their URL http://www.wipeoutcdrepair.com/ They are in Long Beach, California.
I've never had any luck with fixing badly scratched discs...
DvdDecrypter or DVDShrink always crap out as does Alcholo... The only thing I can do is use DVDFabDecrypter to copy the badly scratched dvd and then burn it to dvd-r or +r.... If it needs to be reduced in size, I then run the ripped files against DVDShrink.... Works 80% of the time...
Good SATA drive for read/ripping scratched or damaged DVDs
By darkin in forum DVD RippingReplies: 2Last Post: 19th Nov 2010, 00:47 -
scratched discs
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 17:42 -
Recovering scratched audio CD
By Des in forum AudioReplies: 11Last Post: 31st Mar 2008, 07:54 -
Are some DVD burners better than others at reading/ripping scratched DVDs?
By davlor in forum DVD RippingReplies: 11Last Post: 2nd Dec 2007, 15:03 -
What player for scratched DVD's?
By mad_max911 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 21st Sep 2007, 09:43
