i'm a little confused where DVD menu information is saved. I have a Video TS and Audio TS folder. When I open Intervideo WinDVD I click the open DVD from folder button, it opens the DVD at teh menu. How do I burn this to disk with that menu? If i just dump all the contents of Video TS into the Video TS folder of the disk i want to make will the menu be there?
If you look to the upper left, under 'What is' DVD, then scroll down the page you will see the DVD file/folder structure and where the menus, etc. are. The menus are usually in the VOBS.
If you created them when you authored the DVD, then that's what you will have on the DVD after burning. If you were using Nero to burn, then you would take the contents of the VIDEO_TS folder and drop them into the Nero VIDEO_TS folder when using the DVD-Video template. The audio folder is normally empty and just there for compatibility.
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
DVD menu exists in video ts folder but won't auto play upon insertion
By perceptionist in forum Authoring (DVD)Replies: 3Last Post: 2nd Aug 2009, 06:13 -
How to safely add user data folder to DVD Video?
By fvisagie in forum Authoring (DVD)Replies: 3Last Post: 1st Oct 2008, 07:32 -
Burning VIDEO_TS folder to a DVD disc as Video not Data
By xtaint in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 09:23 -
Burn an already authored DVD-Video folder(VIDEO_TS)
By jain30 in forum Authoring (DVD)Replies: 2Last Post: 12th Jul 2007, 10:02
