I'm adding subs to a bunch of AVI files I've extracted from high-quality DVD sources.
Since they're from solid DVD transfers there's very few problems with the picture quality - but yes, perhaps a little macro-blocking or something here and there.
I was wondering though - what simple filters could I run the AVIs through in either Vdub or TMPG, in order to get an even better, cleaner, and/or sharper-looking picture. So I'm just looking for some good general settings that I could apply to all kinds of different high-quality sources that would make them look subtly but noticeablly better.
I need SPECIFIC settings though - such as "use the sharpen filer in TMPG at 40" or "run Vdub with the dynamic noise reduction at a threshold of 12," etc. Reason being, because I know that all my expirementing has done nothing but confuse me.
Also...is what I'm asking even a good idea or is it likely that I should just leave well enough alone and not risk adding more noise or other issues via unneeded/excessive filtering?
Unfortunately, all our artistic sense are rather subjective. Only YOU can decide which settings are "better" for you. After all, we can't see your screen from here.
Right, I hear you. But just in general what are some good settings to apply that will get rid of what would be considered relatively minor macro-blocking and noise, without compromising other parts of the picture?
What would be a great room size for great video production?
By williec in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2011, 03:43 -
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 22:59 -
VDub - Audio From Another Source - Speed Issue
By hech54 in forum EditingReplies: 5Last Post: 10th Dec 2010, 11:28 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 13:48
