I have 3 AVI files, all XVID, all AC-3, total 2.2 gig. If I use a higher bitrate I3 avi's won't fit a 4.7 DVD. If I reduce <3000 bits, I can fit. If I go to higher and use DVD shrink I can fit.
Which way is best, lower bitrate or shrink an MPEG with a higher bitrate?
I'm sure dual layer is best, but they cost!
Results 1 to 10 of 10
I would reduce the bitrate. Using Shrink might be OK in this type of situation if you just need to go down a little, but using the right bitrate is a better solution.
Another option is to use 1/2 D1 format if you need to make the best use of the bitrate available. A lot would depend on the quality of the video you are converting. -
Well another option of course is to buy a divx dvd player. You can get them for around $50 USD nowadays. That way you just burn the avi's as is without reencoding.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Normal rez for DVD video is 720xwhatever (NTSC vs PAL's vertical rez) You could encode video for 1/2 of horizontal rez, or 360xwhatever, and DVD will still play it, and you will save a bit on the bitrate.
NTSC is normally 648x486. If I reduce to say 324 x 243, how does this change my bitrate setting? Do I double?
What kschang said. And if you look to the upper left for 'What is' DVD, you will see the different compatible formats for a DVD, including 1/2 D1. Generally when you end up with a bitrate down around 2000-3000, 1/2 D1 will do a better encode than full D1.
Take a 5 minute representative clip from your video and try it both ways. It works very well for VHS quality video or your 'average' Xvid, but saves a lot of space by being able to use a lower bitrate.
EDIT: This is the NTSC DVD format
720 x 480 pixels MPEG2 (Called Full-D1)
352 x 480 pixels MPEG2 (Called Half-D1, same as the CVD Standard)
Leave the bitrate the same as you calculated it for Full-D1, but use 1/2 D1 format. It makes better use of the bitrate available. Try it.
NTSC has no connection to resolution. DVD supports certain resolutions only IE 720 by 480 or 704 by 480 or 352 by 480 or 352 by 240.Originally Posted by doggyofone
I gave this a try. Seems to be working OK.
Thanks for the help and lesson!
how can I reduce bitrate and frame rate when converting avi to mpeg-2(dvd)?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2011, 04:42 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 22:25 -
How to reduce bitrate of Xvid without recompressing or faster than this?
By dzsoul in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 06:59 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 10:32 -
How to reduce video bitrate ?
By Sean-- in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2007, 05:47
