Hi,
I got DGIndex, version dgmpgdec146.zip
But I don't know know how to use this, I read the guide...but I need some examples.
What sources does I need ???? i.e. the source can be a multiplexed MPEG2 stream or demuxed audio and video ?
if audio and video must be demuxed, what format of audio does it support ? (WAV ? AC3 ? )
can someone give me a sample of AVS script ?
thanks
Did you read the Quick start guide, there's examples there?
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
thank you
I made some improvements, I learned a lot, but I have another question :
I still have to configure compression/codecs within VirtualDub..isn't it ? i.e. configure bitrates and all that stuff
or is it enough to load AVS script ? -
Yes, if your intent is to output as an AVI, you need to set these settings in VirtualDub. Dgindex and Avisynth merely enable you to frameserve the MPEG video into VirtualDub, they are not encoders.Originally Posted by Delta2"Just another sheep boy, duck call, swan
Mac equivalent of DGIndex?
By ecc in forum DVD RippingReplies: 0Last Post: 10th Dec 2010, 10:37 -
DgIndex and Removing Pulldown
By sambat in forum Video ConversionReplies: 8Last Post: 10th Jan 2010, 08:46 -
Can't get DGIndex to work properly
By iTayb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 22nd Aug 2009, 21:38 -
Problem with Auto GK and DGIndex
By toblerone in forum DVD RippingReplies: 6Last Post: 15th Apr 2009, 18:17 -
dgindex what to choose
By cd090580 in forum Video ConversionReplies: 1Last Post: 29th Feb 2008, 17:33
