I'm having Problems ripping anything using this method, as TEMPEng will not accept the MPEG Audio track, it crashes everytime, no matter what order i load things in (ie Template, Video and Audio Sources). I have tried it with 3 or 4 DVD's and always get the same results.
TEMPEnc works fine if i use Sefys Guide and i have ripped numerous DVD's b4, but i'd be interested in seeing what the quality difference is between the 2 methods.
Am i doing something Stupid? It won't be the 1st time, lol
Any ideas?
Cheers
Melon
<font size=-1>[ This Message was edited by: Melon on 2001-12-30 12:15:40 ]</font>
Results 1 to 12 of 12
hi im the author of the guide and i have sent a update of the guide to Baldrick and he is stil not puting it up well people are emailing me about this problem so i decied to use toolame and SSRC to encode and downsample the audio i can try to tell you it here but it will take to long to explian...give me 10 mins so i can upload my updated guide to a server so you can download it and use the guide instead
Yeah Pinoy, I tried this guide the other day and the VOB2AUDIO tool just kept saying "cannot open file" or something very similar?? I was locating the 1st file as specified...
Thank You Very Much for the Speedy reply.
I did read your other posts suggesting toolame and SSRC and I have given it a go, but always got stuck somewhere along the line
I lookforward to the update.
Cheers
Melon -
well Melon you can download the updated guide here on my site:
http://www.geocities.com/pinoy2201
bilbogod it is a lst file not a 1st file you can make one your own but SmartRipper makes onefor you...this how you do it open up notpead and type some thing like this:
C:\videos\vts_01.vob
C:\videos\vts_02.vob
C:\videos\vts_03.vob
C:\videos\vts_04.vob
but with the correct directory and number and name of your vob files then after name it "streams.lst" with these signs "
Thanks alot Pinoy, I now have a rip which is as close a possible to perfect and teh sound is excellent.
Cheers
Melon
BTW Your new guide needs altering slightly as it still talks about importing the mpeg soundfile, instead of teh wav.
Cheers
Melon -
Cheers pinoy! I know what the problem was. I'd taken short cuts with the settings on Smartripper and hence couldn't get the later steps to work. I figure loads of people are guilty of getting to excited/ taking shortcuts and then crying for help
O.k. still can't get this to work. It just keeps on coming up with the message "Failed to open a file in the list". Why is this happening?? This is what my lst file looks like in Notepad:-
C:\WINDOWS\Desktop\vts_01_1.vob
C:\WINDOWS\Desktop\vts_01_2.vob
C:\WINDOWS\Desktop\vts_01_3.vob
C:\WINDOWS\Desktop\vts_01_4.vob
C:\WINDOWS\Desktop\vts_01_5.vob
weell why is your vobs on your desktop?? you should rip it in to a folder somewhere where only your DVD Rip work goes thats how i do it and it never fails on me and it is organized
try to put it on a folder and try and dont put it on your desktop but now you have to edit your lst file with the directory you put your vobs in
C:\WINDOWS\program files\blow\vts_01_1.vob
C:\WINDOWS\program files\blow\vts_01_2.vob
C:\WINDOWS\program files\blow\vts_01_3.vob
C:\WINDOWS\program files\blow\vts_01_4.vob
C:\WINDOWS\program files\blow\vts_01_5.vob
Now looks like this, but it's still not having any of it. Same error message again. Unless its a problem with what I am doing I'm going to uninstall and reinstall again.
N.b. Blow is the name of the film...
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
Simple 1-step DVD/Blu-Ray ripping?
By billbo1970 in forum DVD RippingReplies: 17Last Post: 29th Dec 2011, 11:59 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35 -
The Complete Step By Step DVD Ripping/Burning Primer for Mac...?
By oliasdoug in forum MacReplies: 0Last Post: 10th Nov 2009, 07:04 -
Audacity guide for beginners, step-by-step
By AleksandrIgnatov in forum User guidesReplies: 3Last Post: 20th May 2007, 20:34
