I tried Baldrick's http://How to convert MKV to AVI or <a class="contentlink" href="http://www.videohelp....using mencoder, but then I got the following when I used the command
http://<br /> <br /> I tried using Baldrick's <a class="contentlink" href="http://Ho...T_T :sad::cry:Code:C:\Documents and Settings\Owner>"C:\Program Files \mplayer\mencoder.exe" "c:\video\video.ogm" -oac mp3lame -ovc copy -o "c:\video\videooutput.avi" MEncoder dev-CVS-051227-13:21-3.4.2 <C> 2000=2005 MPlayer Team CPU: Intel Pentium 4/Celeron 4 Northwood; Pentium 4 EE/Xeon Prestonia, Gallatin <Family: 15, Stepping: 9> CPUflags: Type: 15 MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 0 SSE: 0 SSE2: 0 compiled with runtime CPU detection - WARNING - this is not optimal! To get best performance, recompile MPlayer with --disable-runtime-cpudetection. 89 audio & 203 video codecs MPlyer was compiled without libmp3lame support. Exiting... <error parsing cmdline> C:\Documents and Settings\Owner>
Results 1 to 15 of 15
Originally Posted by celtic_druid
Originally Posted by kschang
http://corecodec.org/projects/mkvextractgui/
THEN load the pieces into VDubMod and reassemble into AVI. -
libmp3lame is the lib used for lame encoding. If it isn't enabled during compiling then you can't encode with it. In the context of mplayer it is not a codec since you need to disable decoding when compiling lame. mplayer already has two mp3 decoders anyway.
All my mplayer/mencoder builds have lame enabled.
Try: http://ffdshow.faireal.net/mirror/mplayer/mplayer2006.02.22.P4.7z
Compiled for P4's with SSE/SSE2 enabled. -
I think the main problem is that my computer is slow; it has only 256 ram.
Originally Posted by funnybunny
Uh, that's just a bunch of white pixels on black background.
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 11:19 -
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 00:56 -
OGM to AVI/DVD
By liveforit11 in forum Video ConversionReplies: 3Last Post: 20th Aug 2007, 21:20 -
Convert ogm to avi please?
By venus in forum Video ConversionReplies: 13Last Post: 11th Aug 2007, 17:15 -
OGM/SSA to AVI
By defiancexr in forum Video ConversionReplies: 2Last Post: 14th May 2007, 23:33
