Hi All,
I've had recent cause to open up my PC case and noticed that the power supply fan, whilst working, didn't strike me as all that powerful.
I held a small receipt sized piece of paper in the airflow and it flicked around gently. To the "touch", I can feel a subtle breeze if I put my hand a few centimetres from the fan (on the outside).
Is this about right? Or should it be producing a stronger airflow?
Cheers.
Results 1 to 11 of 11
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
If it's anything to go by, I have a 450W power supply and from about 10cm from the fan I barely feel anything - akin to something very lightly drawing on your hand with their finger
I have to get to about 3cm away before I can really feel it working.If in doubt, Google it. -
Cheers mate. That's a good guide.
My fan at 3cm sounds like it feels like yours does from 10cm. I've got to nip into a PC shop in Elizabeth Street in the CBD to get a few bits - I'll ask in there too.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Depending on what sort of environment your tower sits in, it may just be that there's excess dust "caked" onto the fan, thus inhibiting the airflow. It's not too hard a job to take your power supply case off and give the fan a really good wipe.
Have you been experiencing problems with it, or are you just a little paranoid ?If in doubt, Google it. -
Originally Posted by jimmalenko
I'll take a look and see if it needs a dusting. Ta.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
hi,Originally Posted by daamon
my 2 cents worth smile...
all the computers i have ever had..... the air flow from the fan has been very noticiable and strong!
the only times when the air flow wasn't strong was when the fan blades and maybe the shaft are very dirty or the fan was wearing out!! -
@ JerryB: Cheers. It sounds like, even though it's working, it's a bit weak.
Carpe diem.
daamon, more important is how much heat is the PS putting out? If it only has lukewarm air or cooler coming out, it's likely doing fine. If it's hot air like a blow dryer, you may have a problem.
Some PS fans have a thermal control for the fan speed. If the PS is running cool the fan speed lowers. Still, it doesn't hurt to blow out the dust occasionally. I have a 480W that runs pretty cool and has very little airflow out the fan. And I've seen some cheap 300W PS's that you could smell burning plastic from the exhaust air. (That one I junked fairly quickly.)
The air is, as you say, only lukewarm. That's a good point...Originally Posted by redwudz
I'll still give it a clean - if it needs it - and leave it to see how it goes.
Thanks all...
Carpe diem.
99.99% they are not powerful at all, just a breeze.
you should clean it and that's it, if doesn't make any noise it's good. -
Cool (no pun intended). The paranoia has settled now...
Carpe diem.
What is this device? (rf in-out with power supply?)
By cynikalhedonist in forum Capturing and VCRReplies: 11Last Post: 23rd Mar 2011, 12:11 -
Power supply numbers
By kenmo in forum ComputerReplies: 11Last Post: 14th Jan 2011, 10:18 -
Question about new Power supply ?
By VEBouto in forum ComputerReplies: 7Last Post: 8th Oct 2010, 15:36 -
Power Supply to Fan
By HotDamn! in forum ComputerReplies: 9Last Post: 23rd Mar 2010, 05:13 -
Power supply problem?
By Ai Haibara in forum ComputerReplies: 17Last Post: 22nd Oct 2008, 13:54
