Hi, I need to rip the subtitles from a DVD in bmp format . I want them to start 1 sec before.
How can I to enter a -1 sec in last time code? The program doesn't allow it
Isn't that possible?
Thanks in advance.
I found out there's a correct time option when the rip is finished. You can choose a minus valor
How do I eliminate the time numbers in a SubRip text file
By Banleno007 in forum SubtitleReplies: 1Last Post: 20th Feb 2012, 10:54 -
Positive or Negative Audio Delay?
By ropdoh in forum AudioReplies: 2Last Post: 11th May 2010, 05:37 -
negative print
By devdev in forum EditingReplies: 2Last Post: 27th Jan 2009, 09:23 -
Negative time code error...
By impmon2 in forum SubtitleReplies: 5Last Post: 21st Mar 2008, 10:22 -
Crop video and make it negative
By Jeremiah58 in forum EditingReplies: 2Last Post: 6th Oct 2007, 23:59
