My DVD Player is set to 16:9 (Wide television conversion):
Select this when the aspect ratio of your TV is fixed to 16:9 (wide TV). The unit automatically adjusts the screen width of the output signal correctly when playing back a picture whose aspect ratio is 4:3.
That way no matter if I’m playing a DVD formatted to 4:3 or 16:9; the picture will always appear full-screen.
The DVD player connected to the Canopus ADVC 100 via S-video cable and high dollar 1/8 inch to RCA splitter.
Nero is set to capture as DV Type II.
Once I’ve captured, I import into Adobe Premiere Pro. The session is set to DV – NTSC, Standard 48kHz.
I load the video, properties read as follows:
Image Size: 720 x 480
Frame Rate: 29.97
Average Data Rate: 3.4 MB / Second
Pixel Aspect Ratio: 0.9
Depth: 24 bits
And you’re saying that once all of my edits are done to export to DV NTSC/16:9 Widescreen?
I’d like to send you the video footage of what happens when I do that. The resulting AVI appears squished from side to side as opposed to from top to bottom. However, if I export as 4:3 (regular) the image appears correct until I encode to PSP. On PSP, the image appears squished from top to bottom. You can especially tell on the watermark.
Got any suggestions?
Results 61 to 61 of 61
Need Help Capturing SD Widescreen Programs
By Kilau in forum Capturing and VCRReplies: 18Last Post: 13th Oct 2011, 10:25 -
Widescreen Problem When Capturing
By DW in forum Capturing and VCRReplies: 4Last Post: 26th Mar 2009, 06:46 -
Capturing widescreen video from Mini DV camera
By eisfeld in forum Capturing and VCRReplies: 7Last Post: 23rd Jul 2008, 20:46 -
capturing widescreen
By odiedog in forum Capturing and VCRReplies: 2Last Post: 4th May 2008, 09:15 -
Capturing Widescreen
By simonw2008 in forum Capturing and VCRReplies: 15Last Post: 7th Apr 2008, 14:48
