I need advice please.
I have a WinFast TV2000 XP Card and I am able to record using the WinFast PVR. It creates a mpeg video file. How can I write these files on DVD?
(I use TNPGEnc Plus, GUI for DVD Author and DVD Shrink to write DVDs from my camcorder avi files). I suppose I need a program to author the DVD before I can write it.
guifordvdauthor can author the mpgs to a dvd.
or click on Tools and Authoring(DVD) in the menu here to the left. -
Ultra short guide
Use TMPGEnc Plus to encode your camcorder avi files to a dvd compliant mpeg2 stream: Select a DVD template and set the output (Stream type) to ES (Video+Audio)
This results in one m2v video file and one mp2 audio file
(You may also recode the audio seperately to ac3 with besweet or ffmpeg)
Select the source in GfD and drag& drop your videofile (the .m2v from the first step) onto the menu background.
Click on 'CreateDVD'
Burn the resulting VIDEO_TS folder (to be found in your selected output directory within the 'DVD' folder) with Nero or any other burning program.GUI for dvdauthor:
https://www.videohelp.com/~gfd/
"The Waveform Cache Files Folder does not have read/write access.
By fionawhitty in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2009, 19:25 -
Write error problem with mpeg streamclip
By mattcourage in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 8th Nov 2008, 10:57 -
Best Software to write VOB files to a CD
By docfxit in forum Authoring (VCD/SVCD)Replies: 14Last Post: 21st May 2008, 19:30 -
mpeg files to dvd
By pupa in forum Newbie / General discussionsReplies: 10Last Post: 20th May 2008, 07:01 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
